which way does the oil filter go? no marks
Old Mar 29, 2008 | 08:45 AM
oliverancher06's Avatar
Default which way does the oil filter go? no marks
Guys I have a 2006 Rancher 4x4 TRX400FA. The oil filter is the circular paper cartridge filter that is just replaced. I keep reading that there is a right and wrong way to put the filter in. I have looked and can tell no difference in the either end, there are no marks on the new filter or the old one indicating which way the flow is. Both ends are identical. Can someone please help. Do the 05-current models not require the filter go in a specific way. By the way, I bought the Honda filter.
Old Mar 29, 2008 | 09:24 AM
sdm111's Avatar
2 strokes or 4
I would hold off on putting it in till someone with a Rancher chimes in cause I have an 05' 400ex and mine can be put in backwards. I get mine from Honda and it tells on the filter ends the way it goes. Just to be on the safe side.
Old Mar 29, 2008 | 10:00 AM
HondaMechanic's Avatar
The filter will go either way .. Don't forget the washer (spring seat washer) & the spring .. The washer will be stuck to the old filter and you have to remove it to re-use it ..
Old Mar 29, 2008 | 10:13 AM
Thank you very much, I appreciate the response
Old Mar 29, 2008 | 10:40 AM
jrafter's Avatar
one end should have a rubber ring on it that end goes to the outside ....you said both ends og your filter look the same
you should really make sure you have the right filter
Old Mar 29, 2008 | 01:01 PM
The TRX400FA/FGA oil filter will go either way ..It has the rubber seal on both ends .. Just don't loose the washer/ spring seat ..
Here is a quick pic of the filter for the TRX400 Rancher
Old Mar 29, 2008 | 02:36 PM
jrafter's Avatar
111
BYC
Sep 25, 2015 02:10 PM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
