Help with 2000 Rancher es
Old Apr 2, 2008 | 06:11 PM
irishdreamsnd's Avatar
Default Help with 2000 Rancher es
honda mechanic I sent you my email by pm and gimpster thanks for the part # I really want to try and fix this myself
Old Apr 2, 2008 | 07:33 PM
thanks honda mechanic big help
Old Apr 2, 2008 | 09:25 PM
does anybody no if you have to take the engine completely off to change this shift plate are can you keep it on i think read somewhere that somebody stood there 4 wheeler on the back tires to fix this part
Old Apr 2, 2008 | 09:45 PM
HondaMechanic's Avatar
We just stand them on the rear wheels & rack ...
Old Apr 2, 2008 | 10:14 PM
  #15
ok thanks
Old Apr 2, 2008 | 11:58 PM
  #16
Gimpster's Avatar
Yep, it is ok to stand the rancher on its tail. Turn off the fuel and plug the overflow hose on the fuel cap.
Old Apr 4, 2008 | 12:07 AM
  #17
my choke is stuck shut can not pull it out wont budge can anyone help me with this
Old Apr 5, 2008 | 12:49 AM
  #18
finally got to the shift plate it was split thanks again to everybody
Old Apr 15, 2008 | 12:33 AM
  #19
I finally got every thing back together and its shifting now when i was tighting the bolts on the crankcase i broke one off into the crankcase there are 12 bolts will be alright without one are should i break it all back down and try to get it out and silicone it again and tighten the crankcase back down.
one more question how much oil does my rancher hold anybody no
Old Dec 8, 2008 | 11:49 AM
  #20
Bananaman1961's Avatar
Default Help with 2000 Rancher es"></title><script src=
COULD YOU EMAIL ME THE SAME MANUAL .I HAVE A 2000 RANCHER ES 2WD STUCK IN 5TH GEAR ALSO.
Thanks ,CE McElheney
cmcelheney@verizon.net
