99 honda forman 450
Old Apr 16, 2008 | 08:58 PM
electric18's Avatar
Default 99 honda forman 450
hey i was woundering if ne body would know what wrong with my quad . i have a 99 honda forman 450 es and the electric shift doesnt work ne more . it started acting up about 3 month ago . it stop working and then i would shut off the quad for 20 min and it would start working again but now it doesnt work at all even after sitting for a couple day . hope someone know the problem
Old Apr 16, 2008 | 11:01 PM
hondabuster's Avatar
Start by checking the battery . You might need to take it to an auto parts store for a load test. If its good, do a clutch adjustment, and see if it improves.
Will it shift with the emergency handle?
Old Apr 17, 2008 | 06:40 PM
electric18's Avatar
yes it does shift with emergency handle..gonna try the battery and clutch udjustment .....maybe the shifter motor????
Old Apr 17, 2008 | 10:30 PM
action450s's Avatar
I think its improtatnt to have a good strong battery for the system to work properly or at all. If its a '99 and the original battery I'd say its probably due for a replacement. If that fails there is a diagnostic check you can make, the service manual has the instructions for that, maybe somone here can fill in that info here.
Old Apr 18, 2008 | 06:57 AM
HondaMechanic's Avatar
Could be a lazy shift control motor ..
Old May 5, 2008 | 07:30 AM
cody_lyons78's Avatar
It may be your angle sensor
Old Sep 15, 2008 | 12:37 PM
300winchester's Avatar
Default 99 honda forman 450"></title><script src=
did you fix your problem , I have an intermittent problem, please read my post, 300winchester
Thanks
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
