How much $ worse case scenario?
Old Apr 22, 2008 | 10:25 AM
outside2day's Avatar
Default How much $ worse case scenario?
Getting bugs worked out, runs strong, no smoke but has some engine noise that is getting worse. Had valves adjusted and chatter seemed to go away..briefly. Now it's back and worse. Did find shavings in crank case. If i pull motor, what would be a ball park worse case on cost of rebuild? May tear apart myself if it doesn't justify its worth. Thanks.
Old Apr 22, 2008 | 10:39 AM
hondabuster's Avatar
It might just be the cam chain tensioner. I know it sounds pretty bad when its that far gone. Have you tried adjusting it? My guess, is its worn out, and the chain is slapping too far, and is wearing on the aluminum casting, causing the aluminum shavings in the sump.. Not a big deal to fix, and not very expensive.
Old Apr 22, 2008 | 10:49 AM
Not familar with this machine, manual be in today or tomorrow. I had right crank case cover off to replace leaking gasket, assume chain was there with a cover or something on it? How do you adjust? Thanks for the help, and would be great if this is the problem. How do you adjust?
EIF
Apr 20, 2017 07:15 PM
Pgbama11
Jan 16, 2016 08:19 AM
WilliamBos
Sep 22, 2015 04:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
