92 honda trx 300 frtx
ok not spark at all on my bike. had buddy pull me to bump start and nothin.starter wont turn lights wont come on wont start with kicker.silinode dosnt make clicking sound so no power.all fuses are good and same for wiring.cdi unit maybe, can they be tested and if so how?
2 things come to mind to check.........
First, check the ground cable connection at the starter - often these get loose or corroded and won't let the electrical system work.
Second, in the battery compartment, there is a plug connector that your Pink and Red Wires from the battery go into - we have seen many times that the blades in the connectors get corroded and even rot off, giving you no power to the electrical system - in turn giving no power to the ignition system.
already toggled last year.every thing was fine. me and a buddy left came back went to jump on to ride and nothing no lights no starter.no spark to coil,i even changed my coil out with new and nada.
dang...........that was has me stumped. Surely someone can help?
Have you tried to jump it to assure your battery didn't short out? Also take the positive and negative cables and test them for continuity with a electric meter.
Could also take the wires off of the toggle switch and see if it starts with the wires touched together. I have seen many many toggle switches die internally.
<div class="FTQUOTE"><begin quote>Originally posted by: trx300man
Could also take the wires off of the toggle switch and see if it starts with the wires touched together. I have seen many many toggle switches die internally.</end quote></div>
Yeah I replaced mine twice already. Water gets in and they wear out quick, or the plate gets stuck and it just doesn't work anymore. It was same story. I started my bike, shut it off, never started again. I got a heavy duty one from radio shack this time, we'll see if it last a little longer.
ok everything is hot (getting)power. still starter wont hit,no starter action just clicking per solnoid.i have changed coil and switches even solnoid. tryed last night to kick, didnt fire up,im from ohio wonder if anyone knows of a atv yard. ratched paw going bad, little hard to kick when you have a sweet spot and it gives out.when i kick over some times i hear a windy sound comming from some where,havent done motor work in two years so dont hink it would be a compression leak, but could be wrong.
