oil in airbox
Old May 1, 2008 | 10:45 AM
rhonda350's Avatar
Default oil in airbox
<div class="FTQUOTE"><begin quote>Originally posted by: jrafter
make sure you dont over fill when you change the oil......also has it been sitting a lot time
and it looks like you need a new airfilter</end quote></div>
no it hasent been sitting for a long time. all that red stuff u see on the filter in the oil u put on the filter.
Old May 1, 2008 | 01:58 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
<div class="FTQUOTE"><begin quote>Originally posted by: rhonda350
<div class="FTQUOTE"><begin quote>Originally posted by: jasonb_32420
im having the same problem. i would like to know also. have you checked the oil to see if its low.</end quote></div>
i checked the oil and its not low its above the mark</end quote></div>
Oil above the mark.....might be your problem right here!
Old May 1, 2008 | 03:08 PM
JeffinTD's Avatar
Agreed. Make sure you are checking it after the machine has ran for 4-5 minutes and sat for 2.
If it's above the mark, drain some out, and see if that solves the problem. If the oil is high enough to contact the crank, it would spray it everywhere, including out the breather...
Old May 5, 2008 | 10:47 PM
rhonda350's Avatar
I drained some of the oil and it runs fine. Thanks for yall help and advices. [img]i/expressions/face-icon-small-happy.gif[/img]
Old May 6, 2008 | 12:38 AM
  #15
contentsunderpressur's Avatar
Be carefull not to over fill your oil. If it still does it then you have excessive blowby and need to rering the engine.
Old May 23, 2008 | 06:06 PM
  #16
AdrianXXX's Avatar
rhonda350!
Did you recognise some loss of power or stalling when you had too much oil?
1986Vmax540
Jul 9, 2021 09:53 PM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
Dammar
Aug 26, 2015 07:12 PM
ghost civic
Jul 20, 2015 12:36 PM
