smoking lots of blue smoke
Old May 20, 2008 | 01:08 AM
rhonda350's Avatar
Default smoking lots of blue smoke
<div class="FTQUOTE"><begin quote>Originally posted by: Ujoint
Check your spark plug like Williebee said - if you are burning oil, you should notice it on the plug - but sometimes if it is not enough oil burning, you won't notice oil on the plug. Then keep an eye on the oil level - if it is slowly dropping level, you are burning oil, just not much yet.
Blue smoke like you are describing can also be an over rich fuel mixture - like your carburetor needle and needle jet may be giving you more fuel at high RPMs than what is required.</end quote></div>
The last time i replaced my plug was like 1 month ago. The tip of the plug was black. I dident look like it had oil on it. The stupid part was that my bike was running kinda lean backfireing whenever u let off the gas. I fix the lean problem though and it dosent backfire anymore. I turned the air/fuel mixture screw out 1/4 of a turn.
This blue smoke has been going on for a while. My friends atv does the same thing
and we have the same bikes but his is a red 4x4.
Old May 20, 2008 | 08:33 AM
Williebee's Avatar
Like i stated in my above post i would get a can of the Sea Foam and mix some with your gas , the instructions are on the can ; you could very well have carbon deposit's inside the combustion chamber causing the rings to stick when the engine gets hot !
I had to try this product before i believed it would do what it claimed to do , and like i stated above i saved no telling how much money on my 88' Jimmy by trying the Sea Foam in my fuel ; i consulted with selveral machanic's who all agreed that the reason for the smoking was carbon deposits builtup in the combustion chamber that was causing the smoking of the Jimmy !
It will be worth the money to try it , it would cost a lot less than an engine overhaul to try this product ; what do you have to loose ? $6.99 + tax at an Auto Parts Store or $5.66 + tax at your local Walmart , one can treats up to 25 gallons of fuel ; to me that's worth a shot and cheaper that the overhaul that you might not need !.....
Cummins Driver
Sep 11, 2019 01:22 PM
dirt ryder
Sep 27, 2015 09:22 PM
KSJOHN
Aug 30, 2015 08:15 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
