400ex foot shifter problem
I would spread the slot enough to get a hacksaw blade in there, and cut the bolt. That should get it off the shaft. Once you have that, you can drill it out or use one of those broken screw removal tools.
Use a drill with a bit that will fit in the hole without drilling out the threads, then use a tap to clean all remnants of the bolt out of the threads.
Frisky2050
Apr 9, 2020 11:19 AM
