Honda Rincon--choke starting problems..
Old Jun 10, 2008 | 10:55 AM
bbush's Avatar
Default Honda Rincon--choke starting problems..
I have a 2005 Honda Rincon that is somewhat difficult to start because of the choke. It will start right up when you choke it, but the minute that you take your hand off of the choke, the choke starts to slide back down. Is there a way to make the choke stay on without it wanting to cutt off when you take your hand off of it? I replaced the choke cable and it helped a little bit, but I am still having problems with it wanting to cut off. Is there a way to adjust the carburetor so that it will "get more choke" and not need to be all the way out in order for the motor to run before it gets warmed up? Once the motor gets warm, it runs purfect. The only problem is that I have to let the motor warm up by holding the choke up before I am able to ride.
Old Jun 10, 2008 | 09:23 PM
JeffinTD's Avatar
On most Hondas you turn the housing around the choke **** to adjust the friction until there's enough to hold the **** out. Grab the round part covered by the rubber boot, and tighten it with your fingers.
Welcome to the forum, and let us know if that solves the problem.
Old Jun 11, 2008 | 08:36 AM
bbush's Avatar
Yes, that looks like that solved my problem. Thanks.....
neilbedwell
Nov 10, 2018 11:02 AM
Honda Side by Sides
27
Aug 14, 2015 01:13 AM
neilbedwell
May 31, 2015 11:11 AM
1000gade
May 27, 2015 12:37 PM
lovinhonda
Jan 25, 2000 09:17 PM
