300 4wd
300 4wd
No! Can't remember the details, but the front and back tires are different heights on the old 300!
The idea is to have the back push more than the front pulls, to keep the steering light. These days, they put a slightly taller gear ratio on the back than the front, but back then they ran smaller tires on front than on back! Rancher tires are both the same height, so they will not work.
What is on it now????
Rims, should fit, but again are you going to be able to find the right tires for those particular rims?
300 4wd
http://www.powerpartsplus.com/...-snow-trail-tire.aspx
if your just lookin for tires id suggest them in your current sizes . theyre real good in the mud and dirt. if you like to sling mud then youll like them. i know i do.
but i know recon rims will fit but the rims are smaller and the tire sizes are smaller.
