2007 TRX500FM Foreman
I originallay had nothing turning, but after talking to hondamechanic, I adjusted my clutch as described (foot shifter), and the fron tshaft started turning. The back shaft still won't turn. I need help. I just bought the service manual. Any direct ideas?
The output shaft (circled in red) runs from the front to the rear in the engine , at the front the front drive shaft slides onto it .. At the rear the rear universal joint slides onto it .. The front is easy to check because you can see the output shaft/front drive shaft , the rear you have to remove the clamp on the swingarm boot then slide the boot off the swingarm to check the universal joint/output shaft ..
Thanks! The output shaft is turning, but not the universal joint. It lloks like the shaft is not in the u-joint all the way, like the swingarm moved backwards some, or the joint broke.
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
