Reserve Tank Question
Old Jul 29, 2008 | 12:28 AM
CoachB47's Avatar
Default Reserve Tank Question
Newb question here so beware...
I am going to assume that when I fill my tank that I am also filling (assuming I use it up) the reserve tank as well. Or do I actually have to switch to reserve then fill IT up. I asked my dealer about it (he was new) and he said it just fills up when you fill the tank up...is this true? If so, what happens to the needle on the tank guage when you go to reserve...does the needle move or does it say empty? Thanks for any advice...
Old Jul 29, 2008 | 12:46 AM
JeffinTD's Avatar
It's all the same tank. The fuel petcock has a tube on it that extends into the tank. When set to run it draws fuel from that tube, so that there is some fuel remaining in the bottom of the tank when it runs out, which can then be used when you switch the valve to reserve.
Old Jul 29, 2008 | 01:10 AM
CoachB47's Avatar
Jeff,
Makes perfect sense...thanks man.
Old Jul 30, 2008 | 01:18 AM
xzachx2112's Avatar
wow, i didnt know what it meant when i read my recon had a reserve tank, and I thoght the RES on the **** meant resevoir or somethin... THANKS
Kyle5050
Dec 13, 2019 04:25 AM
Jazperman
Aug 7, 2016 08:12 PM
Ronk407NY
Feb 13, 2016 11:05 AM
bradco
Aug 21, 2015 08:11 PM
QuadCity
Aug 13, 2015 12:58 PM
