Sea Foam Convert
Thanks Williebee. [img]i/expressions/face-icon-small-smile.gif[/img]
That would save me a step or two. [img]i/expressions/face-icon-small-wink.gif[/img]
<div class="FTQUOTE"><begin quote>Originally posted by: reconranger
If you are smoking because of worn rings, how would something that removes deposits (which are gumming up the rings and sealing them) help??? Kind of goes against logic....</end quote></div>
If you have worn rings this product does not magically rebuild the engine. Sometimes with old engines with crudded up combustion chambers have stuck rings. So the rings will sometimes line up and you get oil burning. Seafoam apparently cleans this freeing up the rings.
No comment on the sea foam
I looked outside at the car that had been sitting without starting fro 1.8 years [img]i/expressions/face-icon-small-shocked.gif[/img] I put a whole 16oz bottle in and a few days later the tank is sitting with broken straps on the ground. Thank you sea foam for removing the tank.[img]i/expressions/face-icon-small-smile.gif[/img]
no comment
no comment
<div class="FTQUOTE"><begin quote>Originally posted by: Raptoryfn660r
I looked outside at the car that had been sitting without starting fro 1.8 years [img][/img] I put a whole 16oz bottle in and a few days later the tank is sitting with broken straps on the ground. Thank you sea foam for removing the tank.[img][/img]
no comment</end quote></div>
Hey Chet,... for rusty bolts on the tank straps, try Liquid Wrench next time. [img]i/expressions/face-icon-small-wink.gif[/img]
#17
I've never put it in my oil, but I have ran it in my gas before and I have fed it in the engine directly through a vac line or into the carb (SUV & mower).
It will clean some crap out of an engine... that's no joke... and if you feed it in direct, want to talk about smoke?... HOLY COW!!!!
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Steeldon
Sep 9, 2015 09:38 AM
