cool down
Old 08-22-2008, 02:06 PM
mannyj's Avatar
Default cool down
what can i do to keep my 400ex cooler? its stock but i have heard of guys putting a fan on it who much do you think that would even help?
Old 08-22-2008, 03:30 PM
kukerdan's Avatar
Default cool down
400ex is air cooled right?
I think the best bet is an oil cooler kit, has to be in air flow, but also has to be out of harms way.. behind a grated grill like a radiator would be the best bet (if you have a nice bumper like that...
You could than add a fan to that too, and hell, you can put valves on the lines, so you can close her up in winter untill she gets HOT
Old 08-22-2008, 03:51 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default cool down
Can you describe why you think you are running hot????
I ride So. Calif. where it can get warm (it's probably 115 degrees today at Glamis!), and while there have been occasions when I thought my lightly moded EX was running hot (like pulling a long dune on a hot day), I have never ever felt that it ran hot in general......
A change in oil might help! Friction means heat, so the slicker the oil you run the less friction you will have, and therefore run cooler. I run Redline ester synthetic MC Oil, which is friction modified with organic modifiers that are still wet clutch safe (!). http://www.redlineoil.com/prod...oil.asp?categoryID=11
Are you running lean for any reason? Like a bad air filter or a leak in your air intake boot?
Old 08-22-2008, 07:20 PM
mannyj's Avatar
Default cool down
from my experiences from a 300ex a had a few years back it just seems like its running hotter and it may not be at all
i run alot of mud and dirt in north central missouri and south ceneral iowa
had a recent oil and filter change about a week ago and used lucas 10w-30 mc oil which exceeds hondas specs so i didnt think that would be it
IMLN
09-28-2015 03:32 PM
Quadzilla Heritage
09-25-2015 01:39 PM
Polaris Side by Sides
09-15-2015 03:33 AM
alzgarvin
09-11-2015 08:53 AM
lancemll88
09-05-2015 03:16 AM
Quick Reply: cool down
