Air Filter Insert
Air Filter Insert
A lot of the UNI filters I have used, come with their own insert that is way less restrictive than the stock insert. One thing I have found with these, is that the collar will eventually bend and collapse under the stress of the band, so don't make the band overly tight and replace them when they get to warped.
If an aftermarket filter does not come with its own insert, then you are stuck using the restrictve stock one....
Steeldon
09-09-2015 09:38 AM
