vent lines
Old Sep 16, 2008 | 11:32 PM
rhonda350's Avatar
Default vent lines
I just took off all the plastic besides the back and I found these vent lines. They had three line routed up to the back of the gas tank. The first one I followed went to a T lookin thing and splited into 2 diffrent lines and both lines went to the carb. The next line I followed went to a T looking thing and splited one going to the front and one going to the back I dont know what these lines go to what u think it went to. The next line I followed I think it went to the back I forgot maybe rear diff idk.
So thats all the lines I need to route up with the snorkel. I was lookin at some other snorkels and noticed they had their vent lines inside their snorkel how wo u do that?
Old Sep 16, 2008 | 11:49 PM
wowkoolaid's Avatar
Default vent lines
do not run the carb vent in the snorkel it will create a vacume and ur bike will run like **** . the other lines r ur diff vents and u should have a rear break vent also u need to extend all of them
Old Sep 17, 2008 | 12:03 AM
rhonda350's Avatar
Default vent lines
o alright so could I run the lines on the side of the snorkel. By the way how do I extend them and how do I get it where theres not much lines what I mean is like connect all vent lines to one line and route it up on the side of the snorkel.
Old Sep 17, 2008 | 12:15 AM
wowkoolaid's Avatar
Default vent lines
go to the auto parts store and get some 1/4 in tube and some splice connectors extend them to front and then put all tubes in to a larger tube (u should have 4) push then in a few inches and then silicone the end of the larger tube and run it up the snorkle
Old Sep 17, 2008 | 12:21 AM
rhonda350's Avatar
Default vent lines
I only got 3 lines
Old Sep 17, 2008 | 12:26 AM
wowkoolaid's Avatar
Default vent lines
well how ever many u have just extend them all in to one and seal it up good
Old Sep 17, 2008 | 12:29 AM
rhonda350's Avatar
Default vent lines
What about the crank case vent or should I just leave it b.
Old Sep 17, 2008 | 06:14 PM
wowkoolaid's Avatar
Default vent lines
i would leave it alone
Old Sep 17, 2008 | 08:43 PM
action450s's Avatar
Default vent lines
The crank case vent is probably already vented to the airbox. On my foreman it attaches to the bottom of the airbox, anymore then 1" of water in the box and it runs right into the engine. I got a longer line and routed it up over the intake boot from airbox to carb and back down where the stock vent attahced to make an upside down trap to prevent this from happening.
I dont know if the rancher is set up the same way as a foreman, I got this and other ideas from triangle ATV.com
ReconBayou
Oct 31, 2022 05:37 PM
Alex G.
Sep 11, 2017 11:38 PM
Mar 21, 2016 06:30 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
