440 big bore
Old Sep 22, 2008 | 04:39 PM
c_kramer69's Avatar
Default 440 big bore
I have a 99 honda 400 with the big bore kit and the stroker kit, so its a 460 now. its pulling my studs out and I was wondering if i could put a stock head and piston on it with the stroker kit. Any ideas, let me know. Thanks!
Old Sep 23, 2008 | 06:33 AM
hotblooded's Avatar
Could you just add a thicker base gasket to get rid of some compression our I suppose that a stock head that hasn't been milled would take away a little squeeze too.
Old Sep 23, 2008 | 12:31 PM
c_kramer69's Avatar
Thanks, i have alot of ?s with this so this helps alot.So with that stroker kit, you can run a stock head and piston, I would still want to run high octane fuel then. And my head bolts are pulling, and suggestions on that to.
Old Sep 23, 2008 | 01:24 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
This happens to alot of the 440's due to the higher compression. Most of them have gone to after market bolts installed.
Achieving higher compression on a 4 stroke is usually accomplished with a different piston, not a shaved (milled) head or thinner head gasket like you would do to a 2 stroke.
You most likely need to have after market bolts installed in your case.
Old Sep 24, 2008 | 10:59 AM
c_kramer69's Avatar
Do you know where i can get those bolts from?
Old Sep 24, 2008 | 01:11 PM
Pirate Biker
Limping Rider!
gtthunder.com
Old Sep 24, 2008 | 02:48 PM
c_kramer69's Avatar
Is this job capable at home?
Old Sep 24, 2008 | 04:09 PM
Pirate Biker
Limping Rider!
Not sure, you may want to get in touch with GTThunder and ask.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
