Shift Problems 2000 rancher ES
I have a 2000Ranchers ES that is stuck in reverse. it started messin up slowly . it wood do fine in all the gears except reverse it woodnt shift out of it. at first rocking helped but now its STUCK. i cant shift electrically or manually . everyone says it is the angle sensor. is that it. or could it be the ECM?
First, be absolutely sure it won't change manually. If it won't, then something mechanical is bent or off. .... most likely something here....... http://216.37.204.206/hondapar...sp?Type=13&A=122&B=15
but possibly also in your shift motor. Either way someone who knows how to check and possibly open up one or the other will have to get the tools out
KimSJoh
14
Jul 18, 2015 07:20 PM
