Hot Cams
Old Nov 10, 2008 | 11:08 PM
Gagt518's Avatar
Default Hot Cams
Well what happened is that my timing chain stretched out and making a ticking noise on whatever its rubbing on. We did a vavle adjustment and all of them were fine. So he said i should buy a Heavy duty timing chain and a chain tensioner since that could be shot aswell. He also said since were already in there and everything is off we should replace the sprokets as well. He told me he would hate to just replace the chain and later come back for a chain tensioner. Since everything is off i was going to buy the HotCam Stage II Cam. He said he would recommend it but i would need a different chain tensioner. I tried calling him today but he didnt return my call yet. Im going to get answers for us tomorrow
Old Nov 10, 2008 | 11:18 PM
700V-fla$h^.^'s Avatar
Default Hot Cams
If your chain was stretched it makes sense to change it all while you are there. The single best modd I did was drop in a hot cam, deffinetly the best bang for the buck.
Old Nov 11, 2008 | 09:37 AM
Gagt518's Avatar
Default Hot Cams
What else would i need to drop a Stage II HotCam in? Nothing right? I think im going to leave the sprokets alone untill i see them in person when we open her up. Im going to pick up a Chain tensioner also to go with the timing chain.
Old Nov 11, 2008 | 10:02 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Default Hot Cams
IMO the ONLY reasons to change sprockets on a 400EX is 1.) They are wore out or 2.) 22" tires.
Old Nov 11, 2008 | 10:30 AM
  #15
toondritetothabak's Avatar
Default Hot Cams
It probably wouldnt be a good idea to change the timing chain gear ratio................But, ya, if you change the chain you should change the sprockets. Your mechanic sounds legit. If he looked at it and recommends changing the tensioner , then I would do it.
Old Nov 11, 2008 | 10:38 AM
  #16
Koopa's Avatar
Default Hot Cams
Oh, whoa. Are we talking about drive chain sprockets or timing chain? Shouldn't need change anything sprocket on the timing chain.
Old Nov 11, 2008 | 03:19 PM
  #17
Gagt518's Avatar
Default Hot Cams
Im talking about the sprokets for the timing chain. He said he would change them if it were him. But im not going to buy the sprokets unless i need them (Worn out) If they are worn out when we take it apart then i will order a new sproket. It would be a OEM sproket so it wouldnt change the timing at all.
Old Nov 11, 2008 | 03:36 PM
  #18
Koopa's Avatar
Default Hot Cams
Hmm. Never seen one wear out before. Don't mean it can't happen.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
