code question
Old Nov 10, 2008 | 03:59 AM
mikeg23836's Avatar
Default code question
hey guys just joind this forum in despret need of help. i have an 04 foreman S with a 100 code flashing on the screen. if i let it sit for a day or two it will start right up and run for about 30 seconds then die and will not start again. she has sat for about a month so i know the gas is probably bad. will have to fix that first. if anyone can help i would be greatly appreceiative.
Old Nov 10, 2008 | 06:54 AM
HondaMechanic's Avatar
Are you sure that is not the clock flashing..?.. When you start it and after it quits does the battery sound strong , like does it turn over good but just won't start ..?..
Old Nov 12, 2008 | 03:58 AM
mikeg23836's Avatar
guess i jumped the gun alittle bit..........just the carb was gummed up and the 100 flashing was the clock........ damn i feel dumb oh well but thak you for replying to my post so quickly i think i will learn alot from this forum.
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
