honda 300ex
Old 12-02-2008 | 10:29 PM
Y2daT's Avatar
Default honda 300ex
dont give up .....keep working ...lol
  #42
Old 12-02-2008 | 10:42 PM
lilc9928's Avatar
Default honda 300ex
lol i'll never give up on this 300. Seriously.
But i gotta question.
ive driven clutches before I know im no expert or anything but if you have it for example in first gear and then hold the clutch, isnt it suppose to roll freely instead of locking up like its in gear?
  #43
Old 12-02-2008 | 10:52 PM
brungardt's Avatar
Default honda 300ex
hey go on rockymountainatvmc.com and look at the plastic they have.. they might have that front piece u need..
  #44
Old 12-02-2008 | 11:03 PM
brungardt's Avatar
Default honda 300ex
take ur spark plug and keep it hooked up put the end of it on the engine and crank it... if it sparks thats a good sign..also what color was the end of the sparkplug that was in it when u got it?
  #45
Old 12-03-2008 | 04:53 PM
700 sportsman's Avatar
Default honda 300ex
if you have the clutch pulled in, it should roll in any gear as smooth as it does in neutral
  #46
Old 12-03-2008 | 05:24 PM
Y2daT's Avatar
Default honda 300ex
I think its time to start a new topic for this thread ...lol..this one is long....you will be ok without reverse but its so lovely to have it working...and the cluth question..yes it should roll freely when the clutch is pulled in you'r clutch cable may be streched,, trace it down there will be an adjustment top and bottom .
you want the cable to have juist a tiny bit of play when the clutch isn't pulled in
  #47
Old 12-03-2008 | 05:54 PM
lilc9928's Avatar
Default honda 300ex
yea this thread is pretty long.
i dont know why but when I put it in gear and pull the clutch it doesnt roll freely.
i rewired the starter switch, No luck, i would shake the atv and sometimes its turnover so im thinking theres a short or something in the wire. Im better off just buying a new wiring harness huh.
  #48
Old 12-03-2008 | 06:55 PM
Default honda 300ex
I would just get a new wireing harness, before who knows what else goes wrong, they aren't cheap but I think its worth it
also there's probably some on ebay
  #49
Old 12-03-2008 | 07:24 PM
lilc9928's Avatar
Default honda 300ex
found one, would this work?
http://cgi.ebay.com/ebaymotors...5fPartsQ5fAccessories
oh and would you know whats wrong with the clutch??? i pull the clutch and it doesnt do anything... the cables hooked up to...
  #50
Old 12-03-2008 | 07:30 PM
Default honda 300ex
on bike bandit the parts#s are the same so it should work
Quick Reply: honda 300ex
