why is my 400ex smoking right after i change the oil
Old Nov 26, 2008 | 12:32 PM
hemicuda7193's Avatar
Default why is my 400ex smoking right after i change the oil
how do u overfill it. it only holds so much.
Old Nov 26, 2008 | 12:54 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
It will holds more than it needs as any engine does. That's why you have a dip stick that says |full - - - - -|add.
Old Nov 26, 2008 | 01:05 PM
Gimpster's Avatar
Lot of good info on here
Sometimes when changing oil, if the oild oil was a generic oil or has been in the quad for a while then Honda oil put in it, they will smoke as the Honda oil will clean tarnish out of the inside of the engine. It has good detergents in it. If this is the case, the quad will stop smoking in a short time once the scum is burned off the pistonm valves etc...
----- Gimpster -----
Old Nov 26, 2008 | 09:48 PM
Honda400-4-ever's Avatar
it seems like it only smokes when i ride it hard and i put 2.0 quarts in the oil tank and i havnt changed the oil since i bought it and i bought it used about 3 months ago its a 2005
Old Nov 26, 2008 | 10:54 PM
  #15
Loshe191's Avatar
Some people overfill the 400EX because they dont know that it has 2 drain plugs
Old Nov 27, 2008 | 12:05 AM
  #16
cherokee99's Avatar
not narrowing it down any, but if its smoking at high rpm's its ether valve seals begining to go, or too much oil. i would change the oil agean. just to make sure you dont have too much oil in it. like loshe191 said there 2 drain plugs
Old Nov 27, 2008 | 10:18 AM
  #17
ill have to check the valve seals but i knew there was two drain plugs and i put in a new oil filter
Old Nov 29, 2008 | 10:23 AM
  #18
reconranger's Avatar
Red Rider
Honda, accept nothing less!
This is an all to common mistake! Be sure you didn't put the oil filter in backward!!! This will starve it for oil and toast your engine!
Old Nov 29, 2008 | 10:28 AM
  #19
Red Rider
Procedure:
http://www.atvriders.com/articles/oilchange400ex.html
What oil did you put in it???? Be sure to run a motorcycle specific oil that is rated API SG/JASO MA. I highly recommend Maxima.
Some good reading:
http://www.thumperfaq.com/oil.htm
http://www.sportrider.com/tech/146_0308_oil/index.html
Cummins Driver
Sep 11, 2019 01:22 PM
KSJOHN
Aug 30, 2015 08:15 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
Dirtbikemike1
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
