Axle nuts
Old Feb 4, 2001 | 11:02 AM
Mike Frey's Avatar
Is it OK to use a socket to tighten axle nuts? I've read that you're only supposed to use an impact wrench because hand-tightened axle nuts don't stay on. I don't see how hand-tightening wouldn't work, but you never know.
Old Feb 4, 2001 | 12:39 PM
Diogenes's Avatar
No castellated nuts, with holes in the axle for cotter pins, Mike?
Diogenes
Old Feb 4, 2001 | 12:55 PM
Mike Frey's Avatar
I don't know what castle nuts are, but yes, there are holes in the axle for cotter pins.
Old Feb 4, 2001 | 06:16 PM
Diogenes's Avatar
Mike, "castellated" nuts have notches cut in them, named for their resemblance to the battlements (firing ledges) on castle walls. These nuts thread onto shafts with transverse holes bored into them. After a nut is tightened onto the shaft, the notches are aligned with the holes and a cotter pin inserted. Spreading the ends of the cotter pin holds the pin in place, in turn preventing the nut from rotating on the shaft.
You asked if an impact wrench was required to tighten axle nuts to prevent the nuts from coming loose. If a cotter pin is inserted through the notches of a castellated nut and bent into place, shouldn't matter how the nut was tightened--impact wrench or hand tool--the nut's not apt to come loose, in my experience.
Diogenes
Old Feb 4, 2001 | 06:53 PM
Mike Frey's Avatar
Thanks for the reply. Just to be on the safe side, I am going to use a friend's impact wrench.
Old Feb 4, 2001 | 08:32 PM
springdrl's Avatar
Let me also recommend high quality, anti-sieze grease to make it easier to remove axle nuts in the future. The best grease for this is made by Bostic and is called Never Sieze. It is expensive ($20 for an 8 oz tube) but doesn't take much to do the job.
It seems too that it is almost impossible to get axle nuts too tight. The idea is to keep the hubs from working loose over time. Many an axle and hub have been lost to those who failed to keep the axle nuts tight.
Old Feb 4, 2001 | 09:25 PM
Mike Frey's Avatar
I'll for sure use anti-seize. I apply it to almost every bolt I remove. Saves lots of hassle down the road. Thanks.
Old Feb 4, 2001 | 09:37 PM
Diogenes's Avatar
I'd recommend castellated nuts and cotter pins, too, just to be safe.
Diogenes
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
raman8tor
Sep 20, 2015 07:35 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
