hole shots q &a
Old Feb 6, 2001 | 12:15 AM
redridaz513's Avatar
how much psi's should i run on 20x11x9?
Are wider tires better or worse?
thanks for info
Old Feb 6, 2001 | 12:48 PM
YZGUY's Avatar
Do a test. Pick a pressure that gives the tread a FLAT PROFILE. This will give you the most rubber on the ground, and your tires will wear evenly. Start with about 4 lbs. If the tire is sagging in the middle, add another .5 lb., and see how that is, then another .5 lbs., and so on. If the tire gets a rounded profile, then you've gone to far. Higher pressures will give a harder ride, and lower pressures a softer ride. Your rim width will effect tire profile also. A wider rim will give a flatter profile than a narrow rim, regardless of the pressure. Wider is better!!
Personally, I prefer the lowest pressure I can get away with. On a stock Honda rim (8" wide), that's about 4.5 lbs.
Sassinm1
Sep 30, 2015 04:23 AM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
toonces
Sep 5, 2015 01:14 PM
