87 250X
Old Jan 7, 2009 | 10:55 AM
budedm's Avatar
Default 87 250X
I was going to take my chain slider off and clean it up a little but after looking at it, it looks like I have to remove the swingarm to get it off. Is that correct? That seems like a dumb thing to have to do just to clean or replace the slider.
Old Jan 7, 2009 | 08:54 PM
johnboy27's Avatar
Default 87 250X
well i went out and looked at mine and well the whole bottom of my slider is gone. lol... but i think even if its one peice you could slice it on the bottom part and slip it over the swing arm.
Old Jan 7, 2009 | 10:09 PM
budedm's Avatar
Default 87 250X
That's kinda what I was thinking. The aftermarket ones are split so I think you can just bolt them on without getting into the swingarm.
Old Jan 8, 2009 | 08:45 PM
Y2daT's Avatar
Default 87 250X
yea that will work ....but removing the swingarm is pretty simple...the choice is yours
Old Jan 8, 2009 | 08:55 PM
Y2daT's Avatar
Default 87 250X
i fyou decide to leave the slider like it is ..put some blocks under the frame of your 250x so they lift the back wheels off the ground then you can leave the rear brakes intact execpt the linkage to the foot/brake pedal connectin to the rear master cylinder....then take off the nut on the left side of the swingarm bolt ...and pull out the swingarm bolt and rear brake pedal out the left side together ,and the swinger should drop down enough to change the top slider ..
Old Jan 9, 2009 | 11:44 AM
budedm's Avatar
Default 87 250X
Ok, thanks Y2dat. That sounds pretty simple. Maybe easier than trying to cut the slider because it's pretty tight quarters in there and looks like it may be a knuckle buster.
big_g_squared
Jun 28, 2015 04:17 PM
rockrider
Feb 20, 2001 02:51 AM
owen350x
Jul 30, 2000 01:58 AM
99_warrior_350
Jun 26, 2000 04:50 PM
YellaTerra
Mar 30, 2000 04:38 PM
