04 400ex sprockets
Old Jan 19, 2009 | 08:09 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default 04 400ex sprockets
One link is all that's needed to be removed, if it's a new chain.
Old Jan 19, 2009 | 08:10 PM
eash.2's Avatar
i will give that a try.thanks.
but all in all i think what i am loking for is how honda sets up there race quads.i have rode one and i cant tell the difference between mine sitting next to it but the ride seems so much lighter more power all the way around.hell i draged that bike had him 1st-3rd but ate me up in 4th like i was sitting still.
Old Jan 19, 2009 | 08:42 PM
Pirate Biker
Limping Rider!
Cam, port and polished head, bigger head pipe and exhaust, different valves, etc,,,,,,
Higher revving (rev box) lightened flywheel, many things are done to the race quads that you can't see.
Old Jan 19, 2009 | 09:18 PM
eash.2's Avatar
thanks for the info.i'll try what i have now and see if i like it.lil more money and a lil more time and i will get it where i want it
Old Jan 19, 2009 | 09:32 PM
  #15
sprayedgt's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Red400EXRod
Higher revving (rev box) lightened flywheel, many things are done to the race quads that you can't see.</end quote></div>
All that plus dropping weight in any and every possible place. There's a reason why race quads can run in excess of $25,000.
Old Feb 11, 2009 | 07:27 PM
  #16
eash.2's Avatar
i went ahead and tuned the bike with16t front 37t rear i did go with the stage 2 cam and jets,aftermarket pipe and rev box.the bike was fast had more torq than stock but after only riding for 30mins my crank came apart and counter bal. came through my motor.now i am back at square one on building another motor.can anyone tell me what caused my motor to come apart like it did?will it be better to build the motor up with the roller crank and the 440 big bore kit or just go with the 416
Old Feb 11, 2009 | 07:43 PM
  #17
moto134's Avatar
i hear about too many problems with the 440 id go with 416 or 426 kit
Old Feb 11, 2009 | 07:52 PM
  #18
eash.2's Avatar
i was told that cause i went with the cam and didnt do my head is why my bottom end came apart.....i know that the 416 is cheaper but will i need the roller crank to go with it or just a hotrod crank kit and will this stop my motor from comming apart
Old Feb 11, 2009 | 08:19 PM
  #19
Pirate Biker
Limping Rider!
If you didn't change the compression the installation of a new cam wouldn't cause the bottom end failure.
Why don't you go with a 426 bore with a stroker crank. This will bring you up to 440 without the huge over bore of your cylinder.
This will also give you tons of torque.
Then have your head ported and polished and you're all set!
Old Feb 11, 2009 | 08:40 PM
  #20
eash.2's Avatar
what is the most comon cost of having the head done
buddieboy
Dec 9, 2016 05:50 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
