Honda 350es 4x4 2004 electric shift problems
Old Jan 21, 2009 | 05:24 PM
Offline's Avatar
Default Honda 350es 4x4 2004 electric shift problems
Hi my honda 350 has some problems i will list
1. wont shift in to revers, wont even try at all to shift
2. sometimes when i shift up out of neutral its sounds like it shifted up then back down to neutral. this happens all through the gears and very offten
It has never gave me a error code for any issue
Old Jan 21, 2009 | 07:57 PM
cherokee99's Avatar
clutch adjustment cured the same problem a gentileman around here had.
Old Jan 21, 2009 | 08:52 PM
Offline's Avatar
i tred that it did nothing
Old Jan 22, 2009 | 12:36 PM
cherokee99's Avatar
2 options that i know of...try replaceing the angle sensor, or takeing it to the repair shop. a proper clutch adjustment has fixed this problem for me in the past. OR adjust the reverse override cable! if there is too much slack it wont engadge the override and wont let you shift into reverse.
foxkill
Jul 24, 2000 01:21 PM
JKB
Feb 16, 2000 06:34 PM
JKB
Feb 16, 2000 07:54 AM
lovinhonda
Jan 25, 2000 09:17 PM
