06TRX400ex
Old Jan 25, 2009 | 10:04 AM
GMCsonoma00's Avatar
Default 06TRX400ex
Im looking for some cheap ways to increase an otherwise stock hp. It has a LRD exaust with matching jets and KN filter. Is there anything else I can do that is fairly cheap?
Old Jan 25, 2009 | 12:57 PM
sprayedgt's Avatar
Default 06TRX400ex
You can do the Sparks Timing Advance Key (about $20) and drop a tooth on the front (about $20) for some added bottom end pull. Both very inexpensive and make a very noticeable difference.
Old Jan 26, 2009 | 03:25 PM
Default 06TRX400ex
Thanks that will help
Old Jan 26, 2009 | 03:28 PM
Default 06TRX400ex
Hey spray?
Could you send me a link to the arrester, im not familiar with those.
Old Jan 26, 2009 | 03:33 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default 06TRX400ex
If you drop a tooth on the front sprocket you may not like the lost topend, if so then drop one tooth on back too, to help regain some of your lost topend but not reducing your gained lowend much.
Old Jan 26, 2009 | 03:38 PM
Default 06TRX400ex
I found it, at http://www.atvriders.com/articles/timingkey400ex.html
Thanks Ill try it
Old Jan 26, 2009 | 05:54 PM
Default 06TRX400ex
thats helpful, so overall a tooth down on front and rear will increase response?
Old Jan 27, 2009 | 11:09 AM
budedm's Avatar
Default 06TRX400ex
That is correct. Let's say your sprockets are 13/38 front & rear. This is a ratio of 2.92 to 1. If you drop to a 12 in front, your ratio will be 3.16 to 1. You want something in between those ratios so if you go to a 12/37 you will have a 3.08 to 1. Or if you leave the front at 13 and change the rear to a 39, you'll have 3.00 to 1. See, when you change the front you have a much bigger effect on the total ratio than when you change the rear. Going from a 13 to a 12 is an 8% change of that sprocket, but going from a 38 to a 39 in back is only about a 2.5% change.
