2000 honda 300 ex chain adjust
Old Jan 26, 2009 | 06:08 PM
carl2000ex 's Avatar
Default 2000 honda 300 ex chain adjust
can anyone tell me how to adjust a chain on a 2000 honda 300 ex
Old Jan 27, 2009 | 07:40 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Haven't owned a 300 in a decade, but I think it is just like the 400 and 450.....
Honda uses an excentric bearing carrier, that you rotate to adjust the chain.
There will be 4 (?) bolts at the back of the swingarm, that hold the carrier tight. Simply loosen them, and then rotate the collar that is at the left next to the sprocket, and it will tighten or loosen the chan. A nice big C-wrentch intended for adjusting shocks works really well on the collar.
You don't have an owner's manual do you??? I also bet you have never adjusted your valves either (????).
Old Jan 27, 2009 | 10:46 AM
budedm's Avatar
Take a 6mm allen wrench and as you sit on the floor behind the ATV, loosen the two allen heads on the back of the axle. Then take the same wrench and fit it into one of the slots on the left side of the axle and rotate the axle ring by pushing or pulling on the wrench. If it doesn't move, spray some WD40 along the seam. You want more slop in the chain than you think. I believe it's 1 1/2". This is because the swing arm pivots in a different spot than the drive sprocket. So, if you were to bottom out the back shock, you wouldn't want the chain to be so tight at that point that it would break.
Old Jan 27, 2009 | 04:16 PM
no I have ordered a owners book but I have never adjusted the valves I have only owned it for a month
Old Jan 27, 2009 | 04:18 PM
Thank You For the advice
Old Feb 2, 2009 | 02:57 PM
Y2daT's Avatar
budem has it down....good awnser ...as well as reconrangers reply.....when i adjust my 300ex rear chain..i use a rachet strap (connected to the swinger and grab bar ) to compress my rear shock
then i turn the berring/axle carrier till the chain has juist the tiniest amount of play
tighten everything up and remove the rachet strap ,then have funn
Scottma518
Jul 16, 2015 09:19 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
MNatv89
Jul 7, 2015 11:36 AM
