2004 TRX450 foreman fuse blown
Old Jan 28, 2009 | 01:15 PM
redline98's Avatar
Default 2004 TRX450 foreman fuse blown
I have limited mechanical skills, and even more limited electrical skills. Keep that in mind if anyone is able to respond and help me with this problem. Thanks!
So here is the deal, the fuse that is linked to the front display unit, lights, and starter keeps blowing. I realize this is probably due to a short (right?) somewhere in the wiring. What I don't know is how to find the short and then fix it. Any advice?
Also, does anyone know for sure whether or not the fan is linked to the same fuse? I can't tell if its running while the quad is running with the blown fuse (quad still runs fine even with out the fuse working, as far as i can tell).
Thanks for the help.
Old Jan 28, 2009 | 02:28 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Are the headlights on the same fuse??? My experience has been that a blow fuse has always been a frayed wire shorting out in the lights somewhere....usually easy to find by just tracing the wires out and seeing if one is pinched or something.
Old Jan 28, 2009 | 02:32 PM
redline98's Avatar
yes, the lights are also included in this fuse. Is there disassembling I need to do in order to get at the wires and follow them from Point A to B?
Old Jan 28, 2009 | 03:27 PM
JeffinTD's Avatar
So is it the main fuse that is blowing? (how many amps?)
Does the fuse blow immediatly when you go to put a new one in? Or does it blow when you attempt to start it or something else?
I agree that the first thing I'd do is look the whole thing over for anything frayed, smashed, or chaffed through.
If you are talking about the main fuse and it blows immediately when you put it in, with the key off, then I think I'd next try disconnecting the regulator/rectifier, then put in a new fuse and see if it continues to blow.
Old Jan 28, 2009 | 03:28 PM
JeffinTD's Avatar
Also, I see these are your first posts here.
Welcome, good luck with it, and let us know how it turns out.
Old Jan 28, 2009 | 03:32 PM
redline98's Avatar
It is not the main fuse, its a 15 amp fuse that runs the front display, lights, and starter. Does anyone know if that same fuse runs the fan?
The fuse does not blow immediately. After changing the fuse, and then riding it for aprox 60 seconds, it blew. Come to think of it, it blew once it was on a bumpy dirt trail. Does that mean its prob a wire that is tapping something and causing a short?
Old Jan 28, 2009 | 04:01 PM
Red Rider
You have a backup pull starter, right? At least you will always be able to make it home.....
Old Jan 28, 2009 | 04:08 PM
redline98's Avatar
Yes, the pull starter came in handy while riding in the river bed in the middle of town at midnight this past weekend (I live in AZ, rivers are empty, fyi). Is there a way for me to find out if that fuse runs the fan also? I was hoping to find a diagram or something like that, that shows what each fuse runs.... If the fan is connected to a different fuse the I think i can still operate the ATV with out causing further damage...
Old Jan 28, 2009 | 04:29 PM
HondaMechanic's Avatar
Fan is a different fuse..
Old Jan 28, 2009 | 04:33 PM
You will have to un-plug the headlights & taillights and test the bike to start narrowing the problem down ...
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
