04 trx450r
Old Feb 17, 2009 | 07:03 PM
250arrrr's Avatar
Default 04 trx450r
What could cause my 450 to lose oil from one side to the other, since they are seperate(motor/trans)...Thnx in advance.......
Old Feb 17, 2009 | 07:43 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default 04 trx450r
Could be a bad gasket on the clutch side case. There is an oil sump at the bottom of the engine case and this is below the trans.
Old Feb 17, 2009 | 09:11 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default 04 trx450r
There is a seal between the engine and trans sides, and that is probably what is leaking. This isn't common, but I have heard of it before. The engine side oil ends up on the trans side leaving the engine level low, so don't even start it up until you get this sorted out! Your top end will get starved for oil!
Get a service manual, and see what you can learn......
01ssls1
Sep 22, 2015 06:50 AM
Aug 5, 2015 02:10 AM
yambam13
Jul 4, 2015 01:49 PM
dorene
Jun 5, 2015 05:25 PM
CyberTrip2003
Sep 12, 2003 10:53 PM
