New 2008 Honda Rancher 4X4 - Electronic Shift
Old Mar 1, 2009 | 06:58 PM
StanD's Avatar
Default New 2008 Honda Rancher 4X4 - Electronic Shift
I too wanted the gauges but the simplicity of the manual shift was a higher priority so I bought the FM model. In order to keep track of service intervals I purchased and installed an hour meter. I would have liked to have had a speedometer but I really doubt that speed will ever be an issue unless I was to exceed the posted limit in town.
Stan
Old Mar 1, 2009 | 08:00 PM
gambler_m_99's Avatar
Why Honda doesn't take advantage of both the foot shift along with the digital speedo is a mystery to me.
Old Mar 1, 2009 | 09:03 PM
trailbuzzer's Avatar
I too choose the ES model for the Digital Dash info . For only$200 more on the ES , one got alot.
I too noticed the Es shifter is lazy when the engine is cold. It could be the temp, or due to the faster running idle speed (I noticed this on my manual shift honda 400 foreman)
Old Mar 2, 2009 | 01:46 AM
JeffinTD's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: StanD
Stan</end quote></div>
You might consider running a bar mounted GPS. That would give you speed/distance and is also a nice navigational aid. I've got an old Magellan on the Foreman, and run a higher end Garmin on the Rincon. A cig lithger plug is also handy.
Old Mar 2, 2009 | 03:23 PM
  #15
StanD's Avatar
Thanks JeffinTD. I have a Magellan I could use and I installed a power plug right after I purchased the Rancher.. Where did you find a handle bar mount. Does it provide a solid mount for your GPS?
Stan
Old Mar 2, 2009 | 05:04 PM
  #16
JeffinTD's Avatar
I got the Magellan brand handlebar mount. At that time that GPS was getting old, so I was able to snag a mount off of e-bay.
There are generic mounts out there, of course, but one that was a custom fit is nice. It locks the unit in place and the power attachment attached to it so there was nothing extra to hook up.
Old Mar 2, 2009 | 06:46 PM
  #17
MEGA XP's Avatar
RAM mounts are also a good solid solution. They are around $40 they have them for most major branded GPS units.
Old Sep 30, 2012 | 08:46 AM
  #18
ToddThomas's Avatar
ok well iv got a fm rancher but my father has the es foreman and what i have noticed is that if you are increasing in speed you have to releace the throtle then shift and its at certin rpms when you have the best shifting its ment so non the less if you were in water you foot dont get wet if thats the case sry you shouldnt have got a atv but its a es just like an auto mattic your suppose to shift as you get to the right rpm and once you get there you let off the throtle and start over at a lower rpm try this if you see a diffrence let me know its just food for thought as you shift up you have to let off your throtle then shift
Old Sep 30, 2012 | 06:28 PM
  #19
tramp's Avatar
Let it warm up a bit.....my FM will even do that if I don't let it warm up a bit.
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
Scottma518
Jul 16, 2015 09:19 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
