400ex oil
Old 03-01-2009, 03:18 PM
yzballa08's Avatar
Default 400ex oil
i have about 10-15 rides since last oil change and i checked my oil and it is water thin it almost looks like it is mixed with water how could this be?
Old 03-01-2009, 05:40 PM
Rkangel777's Avatar
Default 400ex oil
Is it milky or just thin? If it is milky then it is likely water. If it is thin then it could be breakdown from age or fuel getting into the oil from blow-by in the cylinder.
Old 03-01-2009, 08:01 PM
gambler_m_99's Avatar
Default 400ex oil
What kind and weight of oil are you useing?
Old 03-02-2009, 05:58 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default 400ex oil
There are no other liquids in that machine, except oil and fuel. Either your oil is getting trashed so bad that it is losing viscosity, or it is getting diluted by fuel (does it smell gassey????)
What brand and weight of oil are you using???
Do you have any reason to think that your rings or valve seals are bad, and you are passing a bunch of conbustion mixutre pas the piston and into the crankcase. Does the oil breather from the crankcase, seem to have a lot of oil in it, like it is under a lot of pressure???
XxS0ccerstarxX
09-24-2015 11:53 PM
XxS0ccerstarxX
09-24-2015 05:38 PM
XxS0ccerstarxX
09-24-2015 02:02 PM
XxS0ccerstarxX
09-22-2015 02:40 PM
XxS0ccerstarxX
09-22-2015 08:07 AM
Quick Reply: 400ex oil
