Valves Too Tight Honda Foreman??
Old Mar 2, 2009 | 09:14 AM
12guns's Avatar
Default Valves Too Tight Honda Foreman??
So I adjusted the valves a couple weeks ago. I also put some grease on the spark plug and the angle sensor. Problem was I used some other kind of grease the store gave me. It was for Copper wireing on houses. After is sat for a couple weeks, it started harder than usual yesterday. Was missing and backfiring until it warmed up. I'm confident the valves have the right clearance, but was wondering if the "missing" was in line w/ bad spark plug and or wiring w/ the wrong grease. Yesterday I found Dielectric grease and redid the spark plug and angle sensor. Put new plug and seems to run fine.
What are symptoms of valves that are too tight?
Old Mar 2, 2009 | 09:23 AM
Phlogiston's Avatar
Why would you greese your spark plug?
Old Mar 2, 2009 | 09:27 AM
12guns's Avatar
Just the plug boot, to keep water out. I don't plan on abusing my Foreman like the guys w/ snorkles and such, but wanted to do what I can to help waterproof it.
Old Mar 2, 2009 | 09:33 AM
Phlogiston's Avatar
If the store gave you a conductive greese like Never-Seize (great for bolts, bad for everthing else) or No-OX-It (great for battery term, bad for everything else) you may have shorted your plug. Not that it matters here, but in the 80s when ARCO was selling graphite engine oil, that could short out a spark plug too.
Old Mar 2, 2009 | 09:42 AM
Phlogiston's Avatar
What are symptoms of valves that are too tight?</end quote></div>
Backfire through exhaust
Backfire through carb
Burnt valves
Old Mar 2, 2009 | 11:23 AM
12guns's Avatar
No-OX-It was the stuff I put on first. Guess that was the problem.
I'm still nervouse about the valves.
When I adjusted them, I was able to re-insert the feeler gauge time and time again. It would slid in and out w/ a little "scaping" resistance. After it ran yesterday for a few mins, I could lean down and hear the slight ticking. I guess they are ok? If they were too tight, would they be completely quiet?
Old Mar 3, 2009 | 10:04 AM
12guns's Avatar
Started the Foreman up yesterday after it sat overnight. No more problems. Started and ran like it should. Thanks again!
Old Mar 3, 2009 | 11:40 AM
budedm's Avatar
If the valves are too tight (too little clearance), then yes, they would be quiet. If they are too loose, the clicking will be loud. If they are just right, the heat from the engine will cause expansion and close the clearance and they will (should) be quiet. A slight clicking is ok. Did you adjust the valves with the engine completely cold?
Old Mar 3, 2009 | 03:57 PM
Gimpster's Avatar
Honda considers cold valve adjustment at like around 90 degrees engine warmth.
I normally adust valves so I have to pull pretty snug to get the feeler out from the lash area.
Another issue from loose valves is power loss.
----- Gimpster -----
greg74
Sep 10, 2019 03:03 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
Jul 22, 2015 05:00 AM
Dirtbikemike1
Jul 21, 2015 04:13 AM
