Just bought a 06 Rancher 400AT, bad or good?
Old Apr 5, 2009 | 09:23 AM
LocalFireMedic's Avatar
is step 12 incomplete? Looks like it was cut off. Is it just saying I need to remove the rear wheels?
Old Apr 5, 2009 | 09:25 AM
Originally Posted by papahouse
Mine tops out at about 43 / 44 mph. As for the oil just use 10W40 designed for motorcycles or ATVs. The only service I do is oil, filter changes and clean the air filter. Check the diff levels once in a while. Yours looks good, not sure where you're located but if you are close enough to me I'd say just bring it over and we'll check it over.
Well I live in Albany Ga now. Where are you located?
Old Apr 5, 2009 | 09:30 AM
Originally Posted by FourTraxMaxx
Here is a pic of mine
your's look good and clean. Mine's a little scratched up from use but non the worse for wear and I'm sure I'll add a few more to it
Old Apr 5, 2009 | 10:03 AM
you got any pics showing your rear bumper
Old Apr 5, 2009 | 04:02 PM
  #15
papahouse's Avatar
Guess it would be a bit of a drive to Texas
Old Apr 5, 2009 | 04:08 PM
  #16
:yeah i think that would have been quite a tow
Old Apr 5, 2009 | 04:58 PM
  #17
reconranger's Avatar
Red Rider
Honda, accept nothing less!
http://forums.atvconnection.com/showthread.php?t=310470
Old Apr 5, 2009 | 05:08 PM
  #18
Huh? You trying to tell me I have an angle sensor problem?
Old Apr 6, 2009 | 12:25 AM
  #19
Red Rider
Market research indicates that most folks want an automatic utility. Honda responded with a couple of different, needlessly complex designs. I am no fan of belt drives either, but the Honda designs are over the top.
This was never a big seller for Honda, perhaps because it was $1,000 more than a standard Rancher. Note that the new 420AT is similarly priced, but for your money at least you get IRS and a totally new design transmission (that may just be the ultimate automatic trans design?).
This model has had a flurry of problem posts lately, mostly tranny related! Not a flood, but not that many of them out there to begin with, compared to thousands of standard Ranchers. If anybody were asking before a purchase, I would say to avoid this model, as well as the ES shifting standard Rancher.
Old Apr 6, 2009 | 12:31 AM
  #20
well from what I've read, all the problems aren't direct tranny problems. It looks like it's either the ECM not being set correctly or the clutch assy being wore out. I haven't seen anybody post up anything about the hondamatic breaking or haven't problems. Only thing I keep seeing is how it's low on low end grunt.
that being said I prob would have gone with something else if I would have seen this before hand because all I've ever owned is manuals.
But then again it is a honda and I stand by them
