Switching tire size
Old Apr 20, 2009 | 09:04 PM
-JR-'s Avatar
Default Switching tire size
I have an old Honda 350 Four trax in mint shape with orginal tires still .
The front and rear tires are the same size. 24x 9x 11
I have found a deal on some tires with rims that have only 10km on them. $200 for all 4.
They came off of a Yamaha and the add says they will fit honda .Will they ?
Second question is front tires are 25x8x12 rear 25x10x12
Since both tires are the same hieght it should work being a 4x4.
But having front 8 wide and rear 10 wide will it handle diffent ?
Has anyone on this site tried this .
As the new rear rims do not seem to be off set enough as on the honda as the pictures show
New tires
Old Apr 20, 2009 | 09:45 PM
action450s's Avatar
They probably came off a Grizzley or some other IRS bike so the rear rims will be no good for you as the offset isnt correct. Width wise I wouldnt be concerned, most newer bikes have narrower tires in front tehn teh rear, I run 9" wide in front 11" in the rear in a 27" height.
If I were you I'd look for a set of 11" rim tires for your rims, or a set of rims and tires from another honda SRA bike.
Reactant
Mar 30, 2022 02:08 AM
randycraft24c
Aug 5, 2015 02:50 PM
rcappie4
Jul 18, 2015 07:51 AM
cornermike
Jul 8, 2015 11:44 PM
ranvette
Jul 4, 2015 06:13 PM
