Honda 250ex help
Old Apr 29, 2009 | 02:27 PM
WildeL8y's Avatar
Default Honda 250ex help
I have a 2002 thx250ex sportrax. It won't start. It has not been run in 2 1/2 years. So the usual was done, new gas, new plug, cleaned the carb. Turns over untill the battery is dead, but no spark! it ran just fine when it was last in use. Any ideas? I really need the help as I need to sell this thing as I cannot ride it any longer. Thank you in advance for any Ideas.
Old Apr 29, 2009 | 04:33 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Are you sure there's no spark? Most likely cause after sitting so long is bad gas plugging the carb. Was the carb pulled and completely disassembled, cleaned and reinstalled?
Old Apr 29, 2009 | 05:14 PM
WildeL8y's Avatar
Yes. I took it out, disassembled it, totally cleaned it, and reinstalled it.
Old Apr 30, 2009 | 07:05 AM
budedm's Avatar
How are you checking for spark? If it truly is not sparking, and you said the plug is new, I would check fuses, kill switch, ignition switch. Do you have a meter or a schematic?
Old Apr 30, 2009 | 11:38 AM
xcf cAnnoli's Avatar
Banned
where are you from? cause i have a 250 ex and need some parts, and then ill fix yours
wendal
May 9, 2024 09:29 PM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
stcspiderman
Sep 13, 2015 05:15 PM
Jason Campbell
Sep 7, 2015 02:25 PM
