head light upgrade
Old Apr 30, 2009 | 03:11 AM
gt400ex's Avatar
Default head light upgrade
i have a 400ex with a stock electrical system and am thinking of putting hid lights in. will i need to change anything or would the stock set up still keep up?
Old Apr 30, 2009 | 11:17 AM
Amuro's Avatar
I never messed with a 400ex but I installed HID on my Rancher 420. If your 400ex headlight bulb are the same as a automotive bulb then your lucky! It will be an easy install. If not then you would have to mod the HID bulb to fit into the headlamp housing like I did with the Rancher 420. Also you would have to install a separate wiring system for the HID light with a ON/OFF Switch and a inline fuse because the Factory light switch does not supply enough power and amp to handle the HID. It would just keep blowing the fuse if you try to use the factory switch (the thing is every HID kit is different and pull different AMP.) Trust me the upgrade is worth it though!!!
Old Apr 30, 2009 | 11:49 AM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Go to; rickystator.com and you can answers to all your lighting questions.
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Bulgin88
Aug 1, 2015 06:39 PM
ScopeZ_
Jul 28, 2015 01:44 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
