03 rancher leaking fuel?!
i have an 03 Honda Rancher 350 4X4, and it is leaking alot of fuel. the fuel comes out of a little black tube that comes out just behind the middle skid plate. what is that tube and what is the problem?
It would be nice, if you haven't done anything like that before, to have an experienced buddy there to help... or at least a manual.
The tube goes to the overflow/vent for the carb's float bowl. When you take the bowl off the bottom of the carb, you will see the float. Remove the pin that it pivots on, and then remove the float and the valve part. Something is either hanging up, or there's a bit of debris up in the carb at the valve's seat. Be careful not to bend anything to keep the float level correct.
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
