200sx
alright i have finally figured out that i need new tires. Since my new passion is mud riding i feel i need a goodmud tire. i want super swamper tsl s but its only a 200cc...what should i doget it bored out and increse the compression...i have only seen one exhaust and it was a cobra...i think they are like the same crap that dg puts out though...right now i have kenda dirt dogs on it...there good but there warn out...and does anybody know how to make a lift kit.....i'm sure me and the old man could fabricate one for it but we have know idea how to do it
thanks
thanks
Get the Kenda Bear Claws...they are cheap, and good mud tires, and will be good gor the 200SX.
I have Kenda Scorpion tires...Don't get them, they suck in mud.
I wouldn't get any bigger tires than the Bear Claws for the 200SX, If you do get bigger tires they will rob the horsepower. If you have the money and really want more speed and power then go get it bored out, maybe a port and polish to while your at it.
A lift kit for the 200SX would be damn awsome...they need more ground clearance in mud(personal experience)...you should try making blocks to go under your shocks...take some pictures when you are all done if you do it.
Take a look at those Bear Claw tires, the lugs on them are pretty big but not too big so they will rob your horsepower.
recommend maxxis surtraks
only 2ply.........but still take a pounding
being only 2 ply they should be a bit lighter....robbing less hp
200sx has a lift kit on it lol.......the suspension on the front is set up high already
On the back with my skid plate it's like 2inches...LOL...I will double check it with the tires pumped up.
Get the Bear Claws...they are way better than what pudding said(no offence). Bear Claws are a good all around tire...mostly in mud.
Hey pudding...can you adjust the rear shock at all, so it's more stiff?? or higher...I know the fronts can't be adjusted.
what are the lightest wheels. i'll probably just get itp steel wheels but what other ones are light...and also if i want to get it bored out what is the best company to send it to...if i do i'll get it 40 over
