Engine boggs down when applying throttle
Old Nov 17, 2009 | 11:18 AM
mudhead10's Avatar
Honda 450300 is exactly correct(except I can't go riding with mine).I
Old Nov 17, 2009 | 11:29 AM
mudhead10's Avatar
Honda 450300 is exactly correct(except I can't ride mine).I hooked up a temporary tank with no difference.It's getting plenty of fuel.If other people have this same issue,there must be a solution out there somewhere.(Sorry about the remark I made before,it's just that I'd like to push this quad over a cliff in a fiery ball of flame).
Old Nov 17, 2009 | 12:15 PM
xcitmt's Avatar
NP Mudhead, we have all been that frustrated... I have to agree with the above... it sounds like you are getting crap in your fuel. I have a fuel filter on my 400 and even with what I thought was good gas.. I clean crap out of the filter all the time. I would suggest a fuel filter and maybe take the tank off and give it a good rinse.
Old Nov 17, 2009 | 01:35 PM
mudhead10's Avatar
I'll start from scratch with new/clean everything.I'll let you guys know what happens.Thanx.
Old Nov 17, 2009 | 07:04 PM
  #15
honda450300's Avatar
Default Update
I took my quad to get worked on by a tech. Found out the problem. The cam chain is so loose that it skipped a tooth of timing which is why it boggs out. I have noticed a lot of people with 300's having the same bogging out issue. Makes me wonder how many of these have stretched chains as most of them are the older quads.
Old Nov 18, 2009 | 08:37 AM
  #16
mudhead10's Avatar
That's a lot worse than I would have suspected.I'll have to check my timing to verify.Thanx for the info.How is your quad now?
Old Nov 18, 2009 | 10:11 AM
  #17
It is still getting worked on (waiting on parts), in the mean time he reset the timing and it runs like a raped ape. Parts are just under $200 and I will have about 150 in labor.
Old Nov 18, 2009 | 11:09 AM
  #18
mudhead10's Avatar
So if the timing skipped,he must have replaced the chain.Or was he able to tighten the slack?
Old Nov 18, 2009 | 06:56 PM
  #19
Was already tightned as much as it would go. The chain stretches out after a while. Is replacing the chain, tensioner and a couple other small items associated with it. The list price is $125 for the chain, but you can find em cheaper. I am paying $87 fore the chain. Not positive this is ur problem, but it may be a good idea to check it out, expecially if its an older quad.
Old Nov 19, 2009 | 08:35 AM
  #20
mudhead10's Avatar
Considering that mine is a '93 it probably needs it.I'm going to check it out.
skinnyr6
Aug 25, 2023 02:18 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
MNatv89
Jul 7, 2015 11:36 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
