03 400ex please help
Old Dec 6, 2009 | 09:37 AM
lillbro11's Avatar
Default 03 400ex please help
I just bought an 03 400ex and it doesn't want to start i have to pull it behind my truck for 5 minutes to make it run. when it finally starts up the exhaust pipes start glowing. it has a slight backfire out of the carb too. what could be causing this.
it has a curtis sparks exhaust and 165 jet. I have no idea if thats the right jetting for this bike. Its how I bought it. and it was sitting for a while so the carb might be a little clogged I really have no idea. Any help is greatly appreciated.
Old Dec 6, 2009 | 10:19 AM
sdm111's Avatar
2 strokes or 4
Welcome to the forum. From what you're describing. It's probably starving for fuel. I would start by cleaning the carb. and getting a new spark plug. The jets are probably clogged from sitting and when you finally get it started the pipe is glowing from it running lean due to the jets. Running it lean like that is really bad for air cooled engines.
Old Dec 6, 2009 | 11:49 AM
lillbro11's Avatar
if I take the carb off to clean it i will change the jet and i'm curious what the proper jet would be for this setup. personally I thought 165 would have been too big
Old Dec 6, 2009 | 12:27 PM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
If the exhaust is glowing, I would say your jetting is off, could be because of the cooler winter temperatures too...
Old Dec 6, 2009 | 08:18 PM
moto134's Avatar
all depends what kind of jet it is.put a 42 pilot jet in that will help start it a lot easier.and clean the carb really good.let us know!!!
Old Dec 6, 2009 | 08:20 PM
moto134's Avatar
glowing red at idle???????? sounds like the pilot jet is clogged.42 pilot works wonders you wont even need the choke.
Old Dec 7, 2009 | 07:30 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
165 I would think would be close enough to keep it from running like that. A carb cleaning sounds like where you should start for sure.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
