new trx250ex
Old Jan 11, 2010 | 07:51 PM
NewportHillClimber's Avatar
WOW what a can of worms.....lol. thats almost as bad as 2 stroke vs 4 stroke
Old Feb 20, 2010 | 11:54 PM
alalicious1's Avatar
Originally Posted by trx250ex&250bayuo
I just got a new trx250ex. I am likeing it alot. But a tad slow im wodering is there anything exhaust pipes anything for some more speed? Can i jump it stock? Also this ATV is new to me so i would like it if any of yall are familar with the trx250ex can you post just any thing about it good things and bad things just anything? Thanks.
i have a 2003 and its awesome i decked it out for racing and i do real well. i would be the best if it wasn't for the drive shaft. you are only going to get so much power out of a machine when its shaft driven. i recommend putting in a dynojet kit, K&N filter and HMF pipe on it. you will notice a huge differents. when i got mine it was stock and was only able to pull wheelies up to third and now i can in fourth with all the additives. even with all these performance parts it has great bottom end torque and power in 1st through 3rd gear but it seems like it could still use some more power in 4th and 5th. its a great machine and there is not many negatives to it except the rear drum break, the low power in the higher gears, and because i race it is tipsy on corners. i spaced out the tires 5 inches (2.5 inches on each tire) and its a lot more stable. i jump mine all the time and the spacers hold up. last, tires are a factor. if you are looking for faster acceleration you might want to go down in size. but if you are looking for top end get a bigger tire. its all simple physics. the bigger the tire a little mroe top end and the smaller the faster you accelerate.
DLUNA1
Feb 6, 2009 11:13 PM
2many2ride
Jun 17, 2008 12:41 PM
Paulo_bajasaeusb
May 12, 2008 10:45 AM
sandog
Apr 26, 2008 11:24 AM
recones05rox
Feb 22, 2007 09:24 AM
