UNI air filter question
Old Jan 10, 2010 | 04:05 PM
budedm's Avatar
Default UNI air filter question
I have had this problem before on a different quad. Now I have it again on my Recon. When I tighten the band clamp on my UNI filter, it slips off the end of the filter nose. I cleaned the oil off the nose and the inside of the band as best I could but you know how goopy and messy that oil filter oil is. Anyone else have this problem? What the best thing to clean up that sticky oil with?
Old Jan 10, 2010 | 06:14 PM
git_it_rag's Avatar
I'd use rubbing alcohol.
Old Jan 10, 2010 | 09:04 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
hot soapy water and a thorough rinse will usually do the trick. That's the best way to clean a UNI filter to begin with.
Old Jan 10, 2010 | 10:52 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I clean the lips of my filters and the cage with a paper towel that has been soaked in a little gas.
You have the plastic support cage inside the filter, right??? Those cage lips will eventually warp under the pressure of the band, and need to be replaced now and then. A good symptom indicating this, is just what you have described. Even when dry and properly cleaned, they won't stay on anymore. Also, the cage lip can get warped so badly that it can pass dirt, so be careful not to neglect it!
Old Jan 11, 2010 | 06:28 AM
budedm's Avatar
I will try to clean it with gas. The filter is brand new. What worries me is if the band slips off during a day riding without me knowing it. Then I would be passing dirt and dust and could do major damage.
Old Jan 11, 2010 | 08:18 AM
Red Rider
Also clean the rubber intake boot on the machine with a gas soaked paper towel. I have never lost a filter that was properly cleaned.
Also, don't make the band to tight. Just tight enough to seal things off. When you go to tight, it just warps the collar on the cage all the sooner.
Old Jan 11, 2010 | 09:45 AM
budedm's Avatar
Ok. Thanks ReconRanger, you're always a great help around here.
Maybe you can help me with this one? How do you adjust the pilot screw on a 99 recon? What I did was use a screw bit from one of those bit changing screwdrivers but it was difficult. I had to reach way under the carb and be a contortionist.
Ronk407NY
Feb 13, 2016 11:05 AM
Jenn1
Sep 8, 2015 09:16 AM
QuadCity
Aug 13, 2015 12:58 PM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
