Honda Recon choke cable
If not mistaken, there is a plastic hex nut under the rubber cover on the pull end of the choke cable. Pull it back and tighten the nut a little until the cable stays in position when you pull it out.
I had the same problem with an 05 Rancher I used to own and I was told of this fix several years ago.
GregM
Mar 6, 2018 06:53 AM
