87 250x shock fit a 1993 300ex?
Old Feb 13, 2010 | 09:48 PM
Triggerfreak's Avatar
Question 87 250x shock fit a 1993 300ex?
Will a rear shock from a 1987 250x fit a 1993 honda 300ex.
Old Feb 14, 2010 | 09:17 AM
Kroy's Avatar
Yup. Most everything from a 300ex will work on a 250x. Shocks should fit no problem.
Old Feb 14, 2010 | 12:28 PM
mud99's Avatar
I would say yes because the both quads are almost identical with few engine changes.
Old Feb 14, 2010 | 07:05 PM
KNOWSALOT's Avatar
The Facility
It will bolt right up.
But if you want an awesome rear suspension upgrade for the cheap find a good used 2001 Raptor 660 rear shock. It's an Ohlins unit (from the factory) and not only is it night and day better than the 300EX shock, it also lowers the backend a little over an inch when used with a 400EX rear shock spring. I'm not overstating it when I say the ride is night and day...I would pick that setup over any aftermarket shock any day. You just HAVE to be sure it's an 01 Raptor though,...it has the remote reservoir. The 02-up models uses a piggyback reservoir and will not work due to interference with the 300EX/250X airbox.
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
