no upper lubrication in my rubicon
Old Feb 21, 2010 | 03:01 PM
rubiconrebel's Avatar
Default no upper lubrication in my rubicon
Hi. I have a 2007 Rubicon and I have no oil getting to the rocker arms or the cam. I put a gauge on the check port and have over 50 lbs of oil pressure at an idle. Has anybody out there had this problem with a rubicon? Does the oil go through the transmission and then get directed to the head assembly? I have taken the head off and rotated the engine with the starter and there is no oil coming up around the cylinder stud.
Thanks
Old Feb 21, 2010 | 03:51 PM
TRX1000's Avatar
mabey blockage or a cloged oil filter. and 50lbs sounds a little much....
Old Feb 21, 2010 | 06:03 PM
HondaMechanic's Avatar
The pressure is good .. If the top end isn't getting oil you'll have to dis-assemble it until you find the problem .. Has there been any work done on the engine , if there was then was there Hondabond or threebond used or silicone ..
Old Feb 22, 2010 | 05:40 AM
Thanks there was no work done to the engine at all just oil changes.does the oil go through the trans to go up to the head?
Old Feb 22, 2010 | 07:40 AM
tgardner1983's Avatar
I had the same thing happen to my 350 rancher. still havent figured it out. Mine also had not had any work done to it til i took it apart. any suggestions on the 350 or the same as the rubicon?
Old Feb 23, 2010 | 04:02 AM
Old Mar 1, 2010 | 03:21 AM
Thanks I found a piece of rubber stuck in the through shaft of the trans that was all it was
THANKS AGAIN
Old Mar 1, 2010 | 10:15 AM
JRM's Avatar
JRM
A friend of mine used to much sillicone on the valve cover of his xr200r and silliconed the oil galley shut, the rubicon's cylinder also looks as if it sends the top end oil up a cylinder dowl
Old Nov 4, 2022 | 07:46 PM
Honda533's Avatar
Default old thread but...
THANKS AGAIN
Can you elaborate on the fix
650cc
Jun 26, 2005 04:13 PM
Squirrelhunter
Mar 9, 2004 03:35 PM
666akita666
Feb 26, 2002 08:36 AM
cokeisit
Dec 31, 2000 01:33 PM
P.J.
Sep 8, 2000 10:53 PM
