400ex engine problems...please help
Old Apr 13, 2010 | 06:03 PM
minksaved's Avatar
Default 400ex engine problems...please help
I will try to keep this as short as possible....the quad will fire right up and idle and purr like a kitten with no knocking, smoking, or ticking for about a minute or so, and you can even give it throttle and it will respond great, but after a minute or so it will begin to start cutting out and then die within a few seconds. Once this happens i cannot get it started. If I let the engine cool off and try again the next day it will do the same thing. I have adjusted the valves a couple weeks ago because of this same problem. After I adjusted them I went on a hard 3 hour ride at the track, then parked it for 2 weeks, now this. I have readjusted to valves, they were not out of spec by much, but this time, it didn't solve the problem. It's almost like it cranks and runs great, but when it gets hot, it will die. I haven't checked the spark plug, it is hard to get to, I will check it next. It really doesn't seem like it is timing or carb issue because it does crank right up and run great for a minute or so. Right before it dies it will smoke just a little, but other than that, nothing. Thanks so much for reading, please let me know if you have any suggestions, I'm thinking maybe my valve seals are leaking, but I'd love some other opinions.
Old Apr 13, 2010 | 07:03 PM
sdm111's Avatar
2 strokes or 4
Do you turn your fuel off at the petcock after every ride if not the screen in the petcock if you have one ( been a while since I had a 400ex ) may be dirty and letting enough fuel through to the fuel line and carb. while it sits then while your riding it uses that up and can't fill it up fast enough and runs out of gas. Also sometimes when the cdi is going out when it heats up it will quit working. Hope you get it figured out, by the way welcome to the forum.
Old Apr 13, 2010 | 08:03 PM
minksaved's Avatar
Thanks for the advice, I do turn my fuel off when I'm done riding, but I will check the screen. And thanks for the welcome, I am new to forums all together.
Old Apr 14, 2010 | 07:16 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
You don't notice any fuel pouring out of the overflow tube? Sounds similar to what happens when the float needle is gummed up. The Carb slowly overfills with fuel until it sputters and dies.
Reactant
Mar 30, 2022 02:08 AM
Asaran
Oct 8, 2015 11:14 AM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
