Towing Quad
Old May 29, 2010 | 01:58 PM
tmaxx222's Avatar
Default Towing Quad
Is it possible to tow a quad with 2(or 4) of its wheels on the ground behind a car? i have seen caddys that do that for bikes but not for quads.
-steps beside just putting it in neutral?
-having only 2 wheels on the ground make a difference?
-can only certain quads do this without damage?
-after market upgrade needed first?
Old May 29, 2010 | 11:17 PM
TopAce6's Avatar
Possible yes.
Extremely dumb to do Yes.
I dont know whet else to say, but i know i sure as heck wouldnt.
Old May 30, 2010 | 02:37 AM
tmaxx222's Avatar
How would this be any dumber of an idea then doing the same thing with a car which i see on the freeway every time i do out to the desert?
is there a reason im not thinking of that makes it unsafe or is everyone afraid to try something different then whats typically done?
Old May 30, 2010 | 07:40 AM
polymite's Avatar
Some things to concider,
If it is full time four wheel drive this wont work.
This will wear your tires very fast as atv tires are not made for pavement.
Old May 30, 2010 | 08:21 AM
Jerkyking's Avatar
The Quad diffs and tires (2 or 4 wheels on the road) would most likely over heat and and get torn up. I don't think any quad would stand up to the high RPM's of being towed at speeds over 50 miles per hour for more than a few miles.
Even a car towed behind a Motor home is modified slightly to allow it to be done not to cause damage, including electrical connections to make it legal (breaks and turn signals, etc).
Old May 30, 2010 | 09:03 AM
3_Polaris_ATVs's Avatar
My neighbor tows his behind his pickup between farms. So it can be done. I would not, buy a trailer. As said earlier it will burn up your tires for sure.
Old May 30, 2010 | 10:30 AM
JeffinTD's Avatar
From one farm field to another, maybe.
The difference between this and towing a car is you have 4 psi tires that are not highway rated.
Also, many cars must be modified to be able to be towed with wheels down without damage. In many rear wheel drive stick shift vehicles, when you do that only the upper rear shaft in the transmission spins (output shaft). The countershaft sits lower (in the oil) and since it isn't spinning the upper bearings don't get splashed with oil. With 4x4 pickups, having the transfer case in N and the transmission in gear is generally the recommended method, but even then they usually limit speed to like 45, for 30 miles (IE something that should be done in an emergency only).
Old May 30, 2010 | 02:38 PM
drjoe171's Avatar
i actually read my owner man for an 87 big red. they say that stuff will overheat when towed because the lubrication comes from the engine turning the gears, NOT the other way around, even if it IS in neutral.
Old May 30, 2010 | 03:43 PM
honda450300's Avatar
Default Very Bad Idea
Tires as well as bearings are not made for the constant high use. You would be better off strapping it to the top of the vehicle.
Ean
Dec 19, 2022 08:48 AM
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
Frisky2050
Apr 9, 2020 11:19 AM
Ashley S
May 29, 2017 10:54 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
