02 honda trx 500 backfires in reverse
Old Jun 1, 2010 | 07:41 PM
roxiegin's Avatar
Red face 02 honda trx 500 backfires in reverse
so honda trx 500 is backfireing (best description ) in reverse. runs great in other gears but put it in reverse and sputters and backfires . help please
Old Jun 4, 2010 | 11:28 AM
owdiss27's Avatar
rev limiter i had one and it did the same and most all hondas do that when its in reverse to keep you form backing up to fast. or i have seen that when you can start it in gear by pulling the back brake leaver it will be real bad try to push out on your brake to see if that will help you still cant get rid of the rev limiter tho some times id like to but most the time y would i back up any faster
Old Jun 4, 2010 | 11:35 AM
Dirtjunkie85's Avatar
I agree this is the rev limiter kicking in sometimes you can find a aftermarket CDI that will help this problem but again why do you need to go any faster in reverse?
Old Jun 4, 2010 | 12:53 PM
JeffinTD's Avatar
Bypassing the reverse rev limiter with a double throw single pole switch is a pretty popular modification on the Rincon.
I haven't done mine, but when you get hung up good in the goo I could see where it might be handy.
Old Jun 4, 2010 | 04:23 PM
roxiegin's Avatar
so bypassing the reverse rev limiter should stop my backfiring and lack of power in reverse . thanks
Old Jun 4, 2010 | 04:39 PM
roxiegin's Avatar
Question
or is there a sensor that is not working right causing the rev limiter from working correctly
Old Jun 5, 2010 | 10:14 AM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
It is the rev limiter.
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
Scottma518
Jul 10, 2015 12:42 AM
